MC21 Throttle Position Sensor Resistance readings - HELP!!
This topic is locked: you cannot edit posts or make replies.   printer-friendly view
treeboy
Sat Sep 06, 2008 5:48 am » Post: #1 » Download Post
If anyone can help........ (please!!), I get readings as follows:
On the three pin plug on the wire FROM the TPS:
Yellow/Blue (middle pin) to white/red = 4.2 kOhms (throttle shut) and 0.83 kOhms (throttle open)
Yellow/Blue (middle pin) to blue/green = 1.2 kOhms (throttle shut) and 4.66 kOhms (throttle open)
If anyone would help it'd be much, much appreciated - do you get these values or if not, what do you get????
Also, are these things easy enough to come by??
Thanks in anticipation, Rob
(I appreciate I have asked the same question in my other post - am just desperate to solve this niggler of a prob!!)
Sat Sep 06, 2008 12:40 pm » Post: #2 » Download Post
A double post WILL NOT get any more attention than a single post on a topic.
If there's no reply, it's usually because no-one actually knows! Doesn't happen a lot, but it does happen.
