MC18 head advice
FruitLooPs
MC18 head advice
Mon Sep 08, 2008 7:33 am » Post: #1 » Download Post
Right guys, Pulled the heads on the race bike.
Diagnosis time. Lower cyl:
To me it all looks fine except for the bright ring on the piston and corresponding one on the head! how the heck does that happen? Mad no play with the rod on the crank, could the crank have worn bearings causing that damage? (i assume its contact) This is the cylinder that doesnt belch heaps of smoke. The other one when I pulled the exhaust sloshed so i tipped it up in a bucket and got like ~50-100ml of super tar black oily liquid (the spray that was coming out the back of the bike I presume).
Upper cylinder to come soon/tomorrow:
shmokica
1990 Honda NSR250 MC21
Mon Sep 08, 2008 10:11 am » Post: #2 » Download Post
Great pics, it does look like contact, however will leave it to someone more learned on these matters. I would however think that the liquid out of your other pipe is infact un burnt fuel. I had a stuck float in a carb once which flooded one side. It was a pain draining it, as I was concerned it might cause a fluid lock if I ran it. Cheers.
Mon Sep 08, 2008 12:39 pm » Post: #3 » Download Post
Piston to head contact.
FruitLooPs
Tue Sep 09, 2008 12:27 am » Post: #4 » Download Post
And now for the top cylinder (pushes air most of the time instead of firing), argh.
Crown showing more impact damage than the other one? At least he same ring.
Signs of seizure??
And the real damage, heavy scoring down the length of the piston - rings are free still though.
.. And corresponding scoring down the length of the barrel quite deep indeed. Also out of focus, patch of plating that has gone there is another smaller patch missing on the other side .. Sad
The locating pins for the rings are present, the only thing to cause that damage would be something injested or the tip of a plug getting down right?
AFAIK it was run with airbox but no filter.. Confused
Tue Sep 09, 2008 1:37 am » Post: #5 » Download Post
looks like someone forgot to fit the wrist pin circlip
FruitLooPs
Tue Sep 09, 2008 2:19 am » Post: #6 » Download Post
Shocked Evil or Very Mad FFS, you're not wrong .. Just went out and gave it the pin a push and it popped straight out the other side.
Bloody hell, least I know its nothing more than incompetence Mad
Whats your opinion on the piston to head clearance reasons? the rod doesnt seem to have any play on the crank.
shmokica
Tue Sep 09, 2008 2:42 am » Post: #7 » Download Post
I wouldn't have thought that the standard squish would be close enough to cause this, so maybe the barrels/heads have been altered. I think there may have been different height barrels SP/R, but once again will leave this for the experts. Running an extra or thicker base gasket may be sufficient to get the squish right. The fact that it's on both cylinders means atleast whatever the person did was consistent...
FruitLooPs
Tue Sep 09, 2008 4:10 am » Post: #8 » Download Post
Haha I said the exact same thing to my mechanic/machinist Shmokica.
There has been some DIY work on the ports, so I wouldn't put **** headwork out of the question.
Took the top off one and it's running a single gasket up the top (were they multi layer originally by chance??)
The gouge in the port isn't high enough to affect compression apparently either. So my friend/acquaintance (from my previous 2stroke addictions Razz ) is going to sort the head out to stop it contacting (machinist by trade) lap the gasket surface flat and get it in a state to be used. I trust him well and he is pretty onto it preparing 125GP and RS250 machines on a regular basis, so he can make my bunch of bones ring a ding ding once more!
Tue Sep 09, 2008 5:10 am » Post: #9 » Download Post
hang on a mo. Can you take a picture of the exhaust port? I mean fire a shot from the outside in.
FruitLooPs
Tue Sep 09, 2008 5:45 am » Post: #10 » Download Post
Actually I can't, barrels are at the guys place for the heads to be lapped flat etc.
What're you thinking has been done Matt?
One of them has a crack across the exhaust bridge up the top of the joint, goes about halfway across the width of the bridge.
Tue Sep 09, 2008 1:14 pm » Post: #11 » Download Post
MATT!! Wink
I know what you're thinking! Laughing Not easy to see, but take a close look at the bottom of picture one... I think those barrels should be running single ring pistons! Wink
FruitLooPs
Tue Sep 09, 2008 2:44 pm » Post: #12 » Download Post
OK what would I be looking for, keeping in mind my knowledge about NSR's is entirely from what i've read searched for on this site in the last week or so.
One of the barrels on the bottom has a symbol on it that the other doesn't, looks to be scribed into it a 7 with a line thru it. Almost japanese looking, probably not what you're thinking of?
Tue Sep 09, 2008 6:51 pm » Post: #13 » Download Post
Post some better pictures of the barrels please. (My comment was to Matt... he'll understand when he sees it!) Smile
FruitLooPs
Tue Sep 09, 2008 7:13 pm » Post: #14 » Download Post
FruitLooPs wrote:Actually I can't, barrels are at the guys place for the heads to be lapped flat etc.
Sad I guess it'll forever remain a secret! Razz Once the barrels are back i'll be sure to
Tue Sep 09, 2008 9:06 pm » Post: #15 » Download Post
NSR base gaskets are single piece, stock is 0.5mm, HRC do 0.4's and 0.6's as well.
Head gaskets are just head gaskets, I've got a used one here, it mic's up at 0.3mm.
Stock squish is always within 0.1mm of 1.2mm.
So we can see no matter what you do you'll never get piston/head contact and your barrels are too short for stock pistons by over 1mm.
Clearly your barrels are butchered to hell or not intended to be run with standard NSR pistons. That's why Matt wants a clear pic, so he can see what they are.
But possibily of more importance to you right now is to realise that without quite a hefty amount of work (or just running multiple base gaskets) you'll struggle to get both the squish and the head volume right.
When you get the barrels back measure how tall they are.
