I've had a search on this forum and am looking to see if there are any HK members who can recommend a garage to service and possibly do a little tuning to my MC21. I bought is last year and use it irregularly but it needs a good/big service.
Thanks
Alex _________________ Now bikeless
Previous: NSR 250 MC21
Any thoughts of doing it yourself? The forum has a wealth of knowledge already published in the free section, and most of the guys here are more than helpful when you ask a question (don't forget to use the search function first).
I've had a good look around using the search and discovered how much info is here. Unfortunately i struggle with time and space so some work will always need a garage.
Fortunately i'm quite happy to get covered in grease in my spare time
Thanks _________________ Now bikeless
The NSR is a pretty straightforward motor, so most the the routine stuff should be easy enough, but having been to HK a couple of times, I can aprediate just how little space you actually may have!
As nxrsr20 says though, there probably won't be much you can't do yourself, but I have no idea about a decent shop on the island personally. _________________ Andy.
