just changed my front + rear sprockets and chain, everything re fitted, just took it for a test, and the bike is making a clinking noise
raised the bike and have found that this adjustment or guide thing that is fitted to the swing arm is resting on the chain making the sound...
was the chain supposed to go over this or is it supposed to sit on top.......... now im thinking that its supposed to go over...
but i have nfi.
any help appreciated
cheers
edit* sorted for the moment with a cable tie, will try and get pics as looking at the parts manual comes to no assistance cos im not sure what im looking for, checked the swingarm and frame page but no luck
I have no ideas what you are talking about but would like to try and confuse you more (help out).
yeah i know, i wasnt bothered last night with taking it though, and needed a quick fix. will try and get some this weekend
thnx for the help tho, but try to picture this, where the chain goes, behind the clutch side footpeg, theres a piece of metal that is attached to the rear swingarm (not the bloody subframe like i said earlier ), which hangs down to the bottom of the rear swingarm, and either acts like a guide for the chain... or isnt supposed to be there.
I always thought that the chain guide was a black rubber bit and there weren't any significant aluminium components for the chain to slide on...otherwise you'd have aluminium shavings all through your chain and a drastic result :O
Has the motor ever been out? It's not the torque link that hasn't been refitted is it?
The torque link is attached between the swinarm pivot and the back of the motor on the shifter side to prevent the motor from excessively twisting in the frame. _________________ Andy.
yeah motor has been previously out before by old owner, but im sure its not the torque link your talking about, i think its definately the chain guide but will get pics this weekend for all to see!
