Im in the market for a new set of fairings as i sort of destroyed my old cheap glass ones buy trying to mod them a little.
Im tossing up between the RSW and OE version offered by TYGA.
Just want some info reguarding fitment of both items.
The RSW kit. Does it bolt straight on to the factory mounts, or do i need to move/modify brackets ?
The OE replacment im assuming just bolt straight on ?
Also, both kits both have the section behind the front wheel inclosed where as the genuine farings are vented. Does this effect cooling at all as there is no airflow that would normally run accros the chambers and engine.
I really like both versions. The RSW because its more modern and unique and has a higher screen, but i really like the classic shape of the geniune fairing too.
So i would like some feedback from people who have purchased and fitted either kit. How high is the quality of the glass ? Are the headlights in the RSW kit any good ? Any general feed back would be appreciated.
