I'm posting this for my friend James. Please contact him directly. His info is in the ad below:
complete engine rebuild, with new cylinders,heads new motor mounts,bolts, hrc reed stuffers, hrc harness,030 hrc card, new intrument assembly, new regulator, battery, vacumme module, new sp forks,steering stem,and tryple. steering dampner new front brake disks, 200 miles on tires, new chinese rothmans body set for the track and new oem rothmans tank, some spare oem body panels,rothmans, near new complete rothmans, tail, stock pipes, silencers, new rear sprocket, chain, and spare rear sprockets new.spare magtechs , need repaint,aluminum rims on it now.runs flawless needs nothing look like new, spare front light lens and rear.new seat pad.rear stand included. and is setup for premix have injector bottels but no injector pump for spare. No ca title. jvilnue@aol.com. 805-637-2934.$8,000.00
Here is a link to a photo. The bike was on display at the recent L.A. 2-stroke event:
2strokerider wrote:hi, i am locate in ca too is the bike able to get a ca title?(any paper work?)
I think that the ad said no title. There are some with titles, like mine, but there is quite the premium. Like you said, no more 2 strokes in CA. I also have an NC35 for sale with CA title, but again, you pay extra for that.
Good Luck,
Joel _________________ 1994 MC28 Rothman
TSR250 AC28M
Titles on 2 strokes in the US are very difficult. I have been told, but can't verify it to be true, that the 2 stroke has not been allowed by the EPA for public road use since sometime in the 70's. I can't be sure thats all states or just a select group. I was lucky and found a loop hole which worked like a charm but hard to swing.
