hi all stupid question but, there is a connection for a pipe on the crankcase directly above where the reed blocks go, what should this be connected to? thanks buntz
Its the gear box breather pipe. The pipe just vents to air. The hose should go down the back of the crank cases. _________________ If I have to take the carbs off once more...
