Any suggestions on why the rear cylinder isn't running consistent at idle/low rpms? My ideas center around these issues: plugs bad, inconsistent/weak spark, bad plug lead, weak coil, carb not flowing at capacity through low speed circuit. Bike has factory pipes and around 19k miles. Not sure if it has had wire splice, jet mods or is deristricted. It runs strong when into and past mid-range (5k to redlline). Any help on areas to check is appreciated.
Also, can I run the same plug in the Iridium version?
'96 MC28 SE
'92 MC21 SP
'91 MC21
'89 MC18SP Terra Racing Replica
'85 NS 250R
'85 NS 250R Rothmans Replica
'86 NS 400R
'83 MVX 250F
'82 Motocompo
and a whole lot of other smokers!
[img][/img][img][/img]
Smoke 'em if u got 'em!
