MC18 carbs are a good upgrade too. They are 32mm compaired to the 28mm on the MC16.
Once you've done that you're pretty much up there power wise if its got a good bottom end in it. _________________ If I have to take the carbs off once more...
An MC16 motor with '18 barrels/heads and carbs should make 58-60hp or around 2-4hp more than a RGV!
Stock '18 pipes are super. Never run a set of stock '16 pipes so couldn't say. I would guess '16 pipes will be fine tho. _________________ If I have to take the carbs off once more...
'18 ones are yes. Or you can use '21/'28 pistons but must use them as a pair as the skirt are a little shorter. Better to use '18 ones though.
I have turned down '18 pistons to run in '21 motors hav'nt I Andy. That went really well infact! _________________ If I have to take the carbs off once more...
