Hi eric
you can get a pair of steps from tyga. If you do decide to change the shift patten make sure you rember not to change gears like you normaly would or you will be looking at the sky quicker then you can ask your self "what just happend?"
regards k
I managed to reverse mine to 1 up and 5 down using the stock pegs and gear lever. I just turned it thought 180 deg on the gear box spline. Everything clears and havnt had any probs.
