NF5 Front Fork
melvin0202
NF5 Front Fork
Mon Feb 16, 2009 2:10 am » Post: #1 » Download Post
Can i check if NF5 front fork can fit into my mc28? Do i need to change the triple clamp and wheel shalf?
Mon Feb 16, 2009 2:33 am » Post: #2 » Download Post
you will need to put the stem from your nsr triple clamps into the nf5 triple clamps mate
melvin0202
Mon Feb 16, 2009 2:48 am » Post: #3 » Download Post
OOoo.. icic. Thanks alot si.
Kieran
Mon Feb 16, 2009 7:00 am » Post: #4 » Download Post
Or get a TYGA one...
The Chopster
melvin0202
Mon Feb 16, 2009 8:04 am » Post: #5 » Download Post
Hi Kieran,
You mean we can use Tyga clamps?
Kieran
Mon Feb 16, 2009 8:12 am » Post: #6 » Download Post
No, the machined aluminium stem that they sell...
http://tyga-performance.com/site/product_info.php?products_id=1073
The Chopster
melvin0202
Mon Feb 16, 2009 8:27 am » Post: #7 » Download Post
Ok, now i can get the stem. But i am not sure if the seller is selling is clamps. If he doesnt, anyway way we can find subsitute for it?
Kieran
Mon Feb 16, 2009 8:41 am » Post: #8 » Download Post
Do you not have the triple clamps?
Are they RWU or USD forks?
The Chopster
Mon Feb 16, 2009 1:08 pm » Post: #9 » Download Post
nf5 are rwu
Mon Feb 16, 2009 4:14 pm » Post: #10 » Download Post
NF5 are RWU or USD. I've had both on mine.
NF5 pre 91 are 41mm RWU, same as the NSR, and will fit in NSR triples, although they are very short.
NF5 92 are USD with calipers similar to the NSR.
NX5 93 on have a different caliper pitch.
If I recall correctly, NF5 USD forks will fit into RVF400 triples... but good luck finding a set of those too! Laughing
If it's forks only, see if you can find some data on ZXR400 triples or maybe if you're desperate, RGV triples! If they are the same size you can use those with an NSR sized stem. I've NSR's fitted with both those front-ends.
melvin0202
Tue Feb 17, 2009 1:39 am » Post: #11 » Download Post
Thanks alot for all the info. I am very clear now. Its the RWU which i am intending to get. Cheers!
Tue Feb 17, 2009 3:51 am » Post: #12 » Download Post
Yes, they are short. Those aren't NF5 forks, they are modified NF5 internals matched to NSR parts, with either NF5 or MC18 legs, but I don't recall which.
I can't remember exactly, but I think the difference is something around 40mm. The RS top clamp is not offset as much as difference in fork length.
melvin0202
Tue Feb 17, 2009 4:06 am » Post: #13 » Download Post
But how do you identify if they are real NF5 fork?
Tue Feb 17, 2009 11:01 am » Post: #14 » Download Post
Anything above 80mph is OK!
Kieran
Wed Feb 18, 2009 8:09 am » Post: #15 » Download Post
http://page8.auctions.yahoo.co.jp/jp/auction/h56000006
These are even earlier RS forks, although the triples look the same as my NF5 ones.
Andy... I didn't know that the NF5 went to '93... I thought it ended in 1992, with the double sided swingarm, 90 degree V-machine, and NX5 started in '93 with the SS swinger and 70 degree V.
The Chopster
