Does anyone know the details of part 31100-NKD-970.
Is this for a MC21 & 28? If used on a 21, does it significantly advance the ignition? What type of fuel, AVGAS only or also premium unleaded.
Many thanks _________________ Rich
It's light, compared to a standard MC21 flywheel, but I wouldn't necessarily expect it to be a significant improvement over a lightened MC21 flywheel unless the static timing is the same (or better) than the MC21's.*
* I doubt it is, as it's designed to be used in conjunction with the HRC card and PGM-IV ignition, but this is pure speculation and until someone tries it on the dyno, is my best guess!
Too light on the flywheel also isn't necessarily a good thing, unless you are God on a bike! I was able to out-drag Steve's F3 on a few occasions (with the "old" F3 setup) as the inertia from my heavier flywheel (and a little bit of a weight advantage, so he claims! ) would help grunt out of the corners better. He's also got larger flywheel on his now, and says it's noticeably better, also it will naturally have lost a tiny bit of its "bing... bing... bing" when you blip the throttle. (You'd know what I mean by "bing" if you heard it with the 88~89 flywheel!) _________________ Andy.
I have an MC28 HRC Fly Wheel and stator and looking forward to see in the dyno the differences... I will post the results when i have them...I hope within the next 10 years...
Tonight when i will go home i will weigh the HRC Fly wheel to see the difference from the stock...
First question...: If i use the HRC Fly wheel with 030 card can i use Unleaded Fuel (98 octane and up of course)
Second question...: If i use the HRC Fly Wheel with 010 card do i have use only avgas...?
I've run them all and to be honest the largest of the F3 ones is best. The 88/89 ones are just too small and the motor lacks torque. I guess thats why they added almost 200g onto the later ones.
Mine with a later F3 wheel feels so much better even if it is a little less impressive when reving up without load.
Still F3 is F3 and is nearly always better than stock.... nearly. _________________ If I have to take the carbs off once more...
It may be interesting to some that the kit RS125 crank is heavier than the stock one, for the same reason the F3 flywheel got a little heavier as it was developed.
There's not a great deal wrong with the standard crank really, except that it won't of course work with any of the F3 parts! It does need truing up however, and mass production manufacturing tolerances mean it's not always possible to get a stock crank absolutely true, so you ideally need to pick the best of a batch. _________________ Andy.
