has anyone managed to buy the float bowl seals seperatley? will give allens perf a call in the morning but wiondered if anyone could give me the heads uo.
I think I've got quite a few of these spare. I'll double check in the garage & let you know. _________________ Rich
bike fired up first prod with the foot tonight but was leaking quite a bit from the float bowls, imagine thay must of gone hard after being sat there just over a month
sounds more like a float jam... where are they leaking from did you see? my fuel came out of the drain/overflow pipes, maybe you have the same problem.
If the bowls had not being removed or taken off since a month ago i dont see how the seals can cause a fuel leak. but i may be wrong!
better get a flash light and have a good look before... well if this is happening you got to take the carbs off anyway.
good luck! _________________ feel the wind
no i could see it weeping out between the seals on both carbs, no where near the overfloe etc and floats are fine. if you think about it the carbs are of a 92 bike, they are 17 years old.
