I have a quick question for the experts. I can start the bike, blip the throttle and it revs freely, on occasion the revs will hang up for a second or two, then fall back to idle. Does this sound like an air leak?
Thanks!!
Not an expert but.....could be an air leak but could be something simple like having your idle set a little too high - happened to me - once I adjusted it down to 1250 or so, no more rpm hang up. Maybe you'll get lucky too. Good luck. _________________ -Jim
'93 MC21
It can also be caused by the carbs being alittle out of balance which is a very easy fix and quite simple to check. _________________ If I have to take the carbs off once more...
