water pump
west
    Send private message View user's profile Send e-mail Yahoo Messenger
water pump
Fri Mar 20, 2009 3:06 pm » Post: #1 » Download Post
water pump doesnt seem to be working, do you just replace it straight away?
Just Bought MC16.
Deon
1990 Honda NSR250 MC21
Fri Mar 20, 2009 3:08 pm » Post: #2 » Download Post
If it isn't working, replace it ASAP. Do not ride the bike, you will KILL it.
cgallant
2001 Honda RS250
Fri Mar 20, 2009 3:13 pm » Post: #3 » Download Post
When you say doesn't work, what do you mean? is the seal leaking?
The water pump shaft is driven off the crank shaft. THe impeller shaft also drives the oil pump. So if your impeller shaft isn't spinning, I am thinking you have a bigger issue. If the seals are gone, then you can replace those pretty quickly.
Either way, if you are having an issue with your water pump you should check it out before riding your bike again.
Charles Gallant
DifferentStrokes
Fri Mar 20, 2009 5:03 pm » Post: #4 » Download Post
o o
Last edited by DifferentStrokes on Mon Sep 28, 2009 9:35 pm; edited 1 time in total
west
Sat Mar 21, 2009 9:30 am » Post: #5 » Download Post
i've been told the only way to see if the water pump is working is to check inside the radiator to see if the water is running through the radiator, which is not happening, water seems to just lying still, no movement whatsoever.
Just Bought MC16.
Neal
Sat Mar 21, 2009 10:37 am » Post: #6 » Download Post
Racebox in joburg sell spares for these bikes , speak to Gerhard or Mario
0116098737
west
Sun Mar 22, 2009 9:12 am » Post: #7 » Download Post
thanks dude, will ring em up 1ste thing on monday.
Just Bought MC16.
west
Sun Mar 22, 2009 9:13 am » Post: #8 » Download Post
one last thing, is it just a simple change over with the the water pumps?
is there anything that i need to look out for? any tips?
NSR_hongkong
Tue Mar 24, 2009 2:20 am » Post: #9 » Download Post
water pump is pretty easy to change.. although you need to be very paitient. Also you need to drain your engine oil and coolant..
If your new to this i suggest you get someone to fix it for you because am
sure your gona have a hard time remove the rubber seal and rings from the crankshaft..
It should be around a 3 hour job.. parts is pretty cheap..
i suggest if your gonna change the water pump change the gaskets as well.
