started to notice the bike was not revving too cleanly and struggles between 9-12k allthough it will do it and was feeling a little restricted on a recent ride out, i had a base gasket leak so initially put it down to that but after having the barrels off and replacing the base gaskets the hesitation remains.
checked the pv's and adjustment and all is fine, servo does cycles to full open, recent full rebuild and everthing looks good, the bike does feel like it wants to go but is being strangled. Plugs are ok, fuels good.
bike was performing fine on dyno recently and prob just seems to of crept up,
could it be blocked power jet/s?, i will of course check but just wanted a few other ideas.
just been thinking, the coolant leak I had was dumping crap all over the underneath of the engine, the rear cylinder base gasket was leaking so it was most filthy on the flywheel side, perhaps some of the crap has got in behind the cover and dirtied the pick ups?? I'll have to check tonight.
well the battery is fine, the rectifier's charging at 14v, the pickups and flywheel are clean, the wire splice is good, i've cleaned the fuel filter in the tank, taken the carbs off and cleaned them out inc the power jets, re sealed the airbox rubbers, cleaned and checked the gap on the spark plugs, the pv's line up and servo moves to all positions, all pies are where they shouldbe and still the bike is not doing much from 10k rpm onwards, its like it wants to rev but is being held back. i cant think of anything else to try?
cant imagine anything has thrown the jetting out and can think of nothing else to try, any suggestions folks??
nah nothing like that, everything is sound, runs fine up to 10k, if i was a betting man i'd say power valves but there is nothing wrong, just had the chamber off and double checked them
The only thing I can suggest that you've not already checked is to whip the exhausts off and make sure that the rc valves are actually opening up fully. Mine was adjusted right but the valves werent opening fully! Some wear somewhere so i gave it a bit more adjustment until they were opening fully and now its like a different bike!
ricey3 wrote:nah nothing like that, everything is sound, runs fine up to 10k, if i was a betting man i'd say power valves but there is nothing wrong, just had the chamber off and double checked them
Have you done anything with the airbox? It's never going to give much of a rush with a stock one.
If you've opened it up and not jetted to suit, that will restrain it too. There's no reason why a '21 in good shape and derestricted shouldn't make low 60's and peak around 11,500rpm. _________________ Andy.
