barrels and pistons
HUNTN1
barrels and pistons
Sun Apr 12, 2009 8:53 pm » Post: #1 » Download Post
hi all just getting this right
cylinders
a-large
b-medium
c-small
pistons
d-small
but what letters are medium and
large as i dont want to assume Rolling Eyes is ti c-medium b-large
i got some barrels of the guy i got my bike of and they are c barrels but when i looked at them they both have small cracks between powervalve ports Shocked
so now know that the spare pistons i have are for c barrels and want to fit them into my b barrels till i know [and can afford] new pistons etc,,,
NSR250 MC18
Sun Apr 12, 2009 9:22 pm » Post: #2 » Download Post
Barrel A - piston B
Barrel B - piston #
Barrel C - piston D
Gazza
Sat Sep 26, 2009 11:58 pm » Post: #3 » Download Post
Andy, does this mean that a B piston will run in an A barrel with slightly greater clearance? Or does this mean a B pistol in an A barrel will have too tight a clearance?
NSR250 MC28
NSR250 MC28 - Half finished project
VFR800
Z1000
ZX6-R
Ducati 848 - Gone!
Sun Sep 27, 2009 8:24 am » Post: #4 » Download Post
Gazza wrote:Andy, does this mean that a B piston will run in an A barrel with slightly greater clearance? Or does this mean a B pistol in an A barrel will have too tight a clearance?
It means that a "B" piston will run in an "A" barrel with the correct clearance.
It is a bit confusing, I dont know why they couldn't just letter the pistons A, B & C as well Confused
Gazza
Sun Sep 27, 2009 10:46 am » Post: #5 » Download Post
Sorry I didn't explain that properly. I have pistons (and rings) with no markings on them which should go into B barrels. I'm interested to know if I can run them in A barrels. Do you know if HUNTN1 is correct about the A barrels having a greater clearance/larger diameter than the B barrels?
Queensland Raceway is mainly a couple of long straights (boring track but easier for a beginner to learn). I'd like to run bigger clearances to reduce the chance of an engine cease. Apparently there is a post about this but I can't find it.
Sun Sep 27, 2009 12:14 pm » Post: #6 » Download Post
Try this for reference:
http://nsr250.net/forums/viewtopic.php?p=39364#39364
Gazza
Mon Sep 28, 2009 8:26 am » Post: #7 » Download Post
Thanks - that's exactly what I needed to know
