Rear shock ''gas-charge"?
schwarzy930
Fri May 08, 2009 11:33 pm » Post: #1 » Download Post
hey guys I recently ''serviced'' a OEM "SE" rear shock to a MC28. I added a ''schraeder-valve'' and braided line to replace the worn out OEM ugly rubber line. Question ? What gas ,and how much psi , Evil or Very Mad to re-charge with? I think "nitrogen'' , not just compressor-air, right? and anyone know where to source ''nitrogen'' , if that is the gas used? thanks , dave
zxcvbnm
Sat May 09, 2009 1:00 am » Post: #2 » Download Post
I used to do my MX bikes 10 years ago. I think it was 160psi from memory and I started with nitrogen, but used argon in the end as it was easier to find and free.
You can use Carbon Dioxide in an emergency but it'll perish anything rubber it contacts. You need an inert gas that doesn't expand with the heat or explode and not attack the rubber bladder/seals in the shock.
Canuck13
Sat May 09, 2009 2:34 am » Post: #3 » Download Post
you should be able to nitrogen or argon gas from any welding gas supplier. You will also need a set of gauges/regulator to step the pressure down from the bottle pressure to your required pressure.
DifferentStrokes
o
Sat May 09, 2009 6:28 am » Post: #4 » Download Post
o o
Last edited by DifferentStrokes on Mon Sep 28, 2009 5:11 pm; edited 1 time in total
2Smoke
1987 Honda NSR250 MC16
Sat May 09, 2009 10:13 am » Post: #5 » Download Post
Hi I use Nitrogen and fill to around 120psi when I rebuild shocks. We use nitrogen on the aircraft so its readily available for me!
Paul
