single sided swingarms on an mc18?
dunkenb
1989 Honda NSR250 MC18
Sun May 10, 2009 6:53 pm » Post: #1 » Download Post
wondered if the swing arm from the nc24 would be a good fit?
could then use the nc30 hub assembly to fit an rvf or mc28 wheel???
anyone have any views??
nsrmonkey
Sun May 10, 2009 7:49 pm » Post: #2 » Download Post
I know an NC30 swingarm has been grafted onto an 18 in the past, I believe there were some issues with lining up the shock mounts but it was so long ago and I can't remember properly, some of the other older members may be able to give you some info.
MC21SP - Roth-tax
CBR400 - track
MC21R - sold
MC21SP - sold
Sun May 10, 2009 8:51 pm » Post: #3 » Download Post
http://www.nsr250.net/forums/viewtopic.php?p=22920
http://www.nsr250.net/forums/viewtopic.php?p=10271&highlight=#10271
dunkenb
Mon May 11, 2009 2:40 pm » Post: #4 » Download Post
cheers andy, knew you'd have answers.
think the nc24 swinger will be a better bet than the nc30 as the shock tunnel isn't off set as the exhaust doesn't run behind the right foot peg.
apexxn
Mon May 11, 2009 4:51 pm » Post: #5 » Download Post
Shocked
Mon May 11, 2009 8:16 pm » Post: #6 » Download Post
And then you're stuck with a pig-ugly 4-bolt 18" rear wheel!
Why not just source an MC28 arm off Yahoo! Auctions or TYGA? Personally I don't know what all the fuss is about! Laughing
apexxn
Mon May 11, 2009 8:22 pm » Post: #7 » Download Post
Yea that 4 bolter ain't very cool is it.
Mon May 11, 2009 8:24 pm » Post: #8 » Download Post
It's a bit chunky, the hub's ugly, and the spokes aren't quite the same style as the later NSR's either.
It looks fine on an NC24 I guess, but it's all a bit Heath Robinson to be fitted to a nice lightweight MC18.
Mon May 11, 2009 9:04 pm » Post: #9 » Download Post
Yeah the 4 bolt VFR one isn't very pretty but the normal NSR/NC30 one isn't what you'd call cool either is it.
If you going to fit one it needs to look like this!
apexxn
Mon May 11, 2009 11:26 pm » Post: #10 » Download Post
I guess that depends if you're a hater or not.
Tue May 12, 2009 6:28 am » Post: #11 » Download Post
See what I mean? Who wants a axel that looks like that?
They were doing it right. Then at the last stage decided, no, instead of threading the stub and fitting a nice nut we'll cut the end off, add a through bolt, make a loads of spacers and washers and fit a cheap nut to the end.
dunkenb
Tue May 12, 2009 3:26 pm » Post: #12 » Download Post
that's why i was thinking of using the nc30 hub/axle in the nc24 swing arm , as far as i know the hubs are the same size and the parts are cheap and readily available.
fredie
Wed May 13, 2009 10:36 am » Post: #13 » Download Post
very interesting . some vfr swing arms and wheels are interchangable Wink
dunkenb
Mon Jun 08, 2009 2:45 pm » Post: #14 » Download Post
well i've so far managed to get hold of an nc24 swing arm and an nc30 rear wheel for the grand total of nowt. just need to mount the rear wheel which will require the four bolts removing and replacing with mounting pins, so i may have to get hold of an nc30 hub instead
the nc24 swing arm has the shock centally mounted ( not off set like the nc3) so think it will mount in my mc18 frame without to much fiddling!
does any one know how wide the mc18 swing arm is at the pivot where it mounts to the frame, or has one loose they could measure?
dunkenb
Fri Jul 03, 2009 9:49 pm » Post: #15 » Download Post
http://www.bikepics.com/pictures/1712567/ http://www.bikepics.com/pictures/1712601/
what i've managed to sort so far, vfr400 nc24 swing arm, with vfr400 nc30 hub and wheel. Very Happy
