You can swap the gear shift knuckle to run what your looking for. Simple remove the knuckle from the gear shaft, turn it 180 degrees and put it back on. _________________ Charles Gallant
I run race shift on all my bike and it has already been said its simply turning the knuckle 180 degrees. Be careful though when you first do it as its easy to change the wrong way and lock up the rear or worse. I ended up with a slipper clutch which helped when i got it wrong.
i noticed when i did this, i had a problem with it hitting something, can't remember what it was hitting but i think it was the stock expansion chambers
you can remove the side stand and it should clear no problem. Okay, may not be the best option for a street bike
I know Tyga made a setup that allowed the knuckle to clear the side stand. Not sure if they still make it. Should be able to find it in their site if they do.
Other option is to grind away the side stand to allow clearance for the knuckle to move freely. _________________ Charles Gallant
