lil help
mhunter1175
lil help
Tue Jun 02, 2009 2:03 am » Post: #1 » Download Post
Are the pick up coils and stator the same in the mc16, 18 and 21? I need set for my 21 and have located some for what says 16-18... what do you guys think?
Mike
nsrdownunder
1993 Honda nsr 250 mc21 sp
Tue Jun 02, 2009 9:34 am » Post: #2 » Download Post
Hi
If memory right mc18 stator is different size ,But if u use 18 flywheel should fit may be wrong
mhunter1175
Tue Jun 02, 2009 10:20 am » Post: #3 » Download Post
I fthat is correct th emounting points for the pick up coils wouldn't line up...right?
Mike
Tue Jun 02, 2009 11:24 am » Post: #4 » Download Post
They all do the same job... just pulse a signal as the flywheel turns. The mounts are the same on all the motors I believe, but the spacing (from the crank centre) is obviously different, as is the length of harness coming out of each set depending on model. You may find they are different colour wires on different models too, but nothing that's going to tax a rocket scientist!
There's stacks on Yahoo! Japan. Buy a couple of sets to hedge your bets.
mhunter1175
Wed Jun 17, 2009 9:46 pm » Post: #5 » Download Post
well they are totally different for future reference....$100 lesson learned
Mike
Thu Jun 18, 2009 5:27 am » Post: #6 » Download Post
Pick up lenth is different. MC18 Mk1 won't fit but MC18 MK2 will as long as you alter the connectors.
Thu Jun 18, 2009 2:55 pm » Post: #7 » Download Post
I still can't see why non-MC21 items couldn't be modified.
Thu Jun 18, 2009 3:45 pm » Post: #8 » Download Post
You could of course use the early pick up on a MC21/28 motor as long as you used the right fly wheel. If you didn't then the pick up would smack the trigger on the flywheel.
Thu Jun 18, 2009 5:50 pm » Post: #9 » Download Post
Yeah, unless you slotted the mounts, surely? Confused
Thu Jun 18, 2009 5:53 pm » Post: #10 » Download Post
I've told you before. Don't call me Surely! Very Happy
