'99 RS250 shock on MC28???
jeff, OH
Wed Jun 24, 2009 12:23 pm » Post: #1 » Download Post
Will it fit?
Thanks
Jeff, Ohio, USA
Wed Jun 24, 2009 3:21 pm » Post: #2 » Download Post
in a word no mate but a honda rs 125 from 95 to present will,you just have to get spacers made and shock resprung
Wed Jun 24, 2009 4:09 pm » Post: #3 » Download Post
And change the top rose joint as the RS125 uses a 10mm bolt and the NSR a 12mm one, unless of course you think Honda were wrong to use a 12mm bolt and a 10mm one will do the job fine.
And the remote res doesn't clear the stock subframe/undertray/battery box.
So, apart from being wrongly sprung, wrongly valved, wrong top rose joint and not fitting in the supplied space it's a direct swap.
Wed Jun 24, 2009 6:02 pm » Post: #4 » Download Post
In the words of Dave Ett...
"Very Happy"
Wed Jun 24, 2009 9:16 pm » Post: #5 » Download Post
RS125 Shock
'Wrongly sprung' - Maxton will fit the correct one for £85
'Wrongly valved' - Maxton reckon it's fine
'Wrong top mount' - My Lidl power drill will sort that
'No space' - Hmmmmmm, got me there Stace. A Ha! fit the Tyga subframe
Done.
RS250
No chance!
Thu Jun 25, 2009 6:33 am » Post: #6 » Download Post
How much? Bearing in mind this is a shock that you can change the spring on in about one minute with no special tools that's far from a bargain.
Thu Jun 25, 2009 12:02 pm » Post: #7 » Download Post
The £85 includes a new spring and for them to machine a new ali coller to allow the larger spring to fit the shock.
Thu Jun 25, 2009 4:11 pm » Post: #8 » Download Post
i thought it was good value when they did mine,the spring is twice as big from maxton
