mc21 wire splice not nearly as good as expected.
bandit_7
Tue Jul 07, 2009 8:53 am » Post: #1 » Download Post
I did the wire splice last night and came home from work today to try the bike out. Unfortunatly my bike didn't go faster, it just wouldn't start at all.
I used bullet connector so i could reverse the splice easily. When I swapped back it still wouldn't start.
Anyone had this problem before?
Need help.
Cheers.
DON'T WORRY EVERYONE. PROBLEM FIXED. I BLEW A FUSE AND HAVE REPLACED IT. Only problem now is it just started raining so no ride till tomorrow.
Tue Jul 07, 2009 12:07 pm » Post: #2 » Download Post
You did the work with the battery connected didn't you? Hmm? Confused
Basics! Laughing
bandit_7
Tue Jul 07, 2009 10:13 pm » Post: #3 » Download Post
No but the fuse box has no cover and found some copper filings in there (possibly bridging between main and ignition fuse). And when I connected the battery I also shorted it on the frame. Not sure which part caused it to blow the ignition fuse but all fixed now.
Going for a test run in about an hour so I'm all excited.
bandit_7
Wed Jul 08, 2009 7:31 am » Post: #4 » Download Post
I went for that ride today and all I can say is "F*** yeah". I can feel a good power difference and also runs a little smoother.
The front trys to pick up in first and second with me leaning over the tank. I don't weigh very much though. But am really impressed with the change.
Next thing to do is the GPS splice.
Wed Jul 08, 2009 12:39 pm » Post: #5 » Download Post
Don't worry about the GPS splice. Leave it as it is.
bandit_7
Sat Jul 11, 2009 11:35 pm » Post: #6 » Download Post
Why would you leave the gps? Will it cause problems for my bike?
Jim996
Sun Sep 06, 2009 12:51 pm » Post: #7 » Download Post
Hi bandit_7 and everyone.
I'm Jim from Thailand.
Did you do the jetting after wire splicing?
I'm also thinking about doing wire splice but wondering if re-jetting is required? I have a shop that can do all the maintenance for my bike, but not very sure for the tuning. So I'm quite reluctant.
But if wire splicing is all it needs, I will try soon. Please share with me your thought.
Sun Sep 06, 2009 12:57 pm » Post: #8 » Download Post
You should check the jetting after ANY modification, however a change is not always needed with just the wiresplice. You should modify the airbox at the same time though, else it will still be strangled.
Only a fool wouldn't do a plug chop after releasing 15hp+!
Jim996
Sun Sep 06, 2009 2:17 pm » Post: #9 » Download Post
Thanks a lot Andy for your advice.
So now I know that the most I can get is 45 horses. No reliable person around here to help me for jetting Sad
The mechanic I know doesn't feel like messing with the jetting... haha..he doesn't want to break my bike.
Will my engine run too lean and prone to knock if I do wiresplice and add 4 of 20mm holes?
By the way, sorry that I'm not that good at English.
Would you mind explain me what do you mean by "Only a fool wouldn't do a plug chop after releasing 15hp+!" please? Very curious about it.
Hhhh...15 hp is really tempting..
Sun Sep 06, 2009 2:32 pm » Post: #10 » Download Post
It means "You should check the jetting after ANY modification...".
I would advise going up on the main jets a few of sizes once you open the airbox up, and then come back down slowly, a step at a time if it feels a bit flat.
There's no such thing as a "full power" setting for the NSR as they were only ever sold for the (restricted) Japanese market, so we cannot advise specific carburettor settings. Jet size discussion is not allowed in the public forums for this very reason.
There is a section in the Members Area for jetting discussion.
Jim996
Sun Sep 06, 2009 2:45 pm » Post: #11 » Download Post
Thanks a lot Andy. I will search for more info and will do it one day, hopefully not in a distant time... Very Happy
maximum
Mon Sep 07, 2009 4:47 am » Post: #12 » Download Post
Jim where are you in Thailand ? I m up in Chaingmai.maybe can help you out ?
My Bikes;
TZ250K
TZR250 3XV Sugo kitted track
TZR250 3XV modified road
NSR250R MC21 Rothmans
NSR250R MC18 Modified road
NS400R
Dio 80cc big bore with 26mm flatslide (wicked)
900RR Fireblade
Jim996
Mon Sep 07, 2009 5:55 am » Post: #13 » Download Post
Hi maximum,
I'm in Chonburi. Nice to know you.
I just got this MC21 SP from Chaingmai 3 months ago.
Will need lots of advice from you and folks here. Razz
Would you let me know your contact via jim_996@hotmail.com?
bandit_7
Tue Sep 08, 2009 8:57 am » Post: #14 » Download Post
G'day All.
It's been a while but I have more info on the whole "wire splice and seizure" thing.
I pulled the cylinders off and found out that the top piston seized because...
1. The motor is 18 years old
2. Had original pistons
3. Had home made base gasket (they forgot to cut out the holes for water flow).
4. Was running slightly lean
5. Was being thrashed by an absolute dickhead
32. Wire splice
By the look of pistons it has been running lean for quite a while.
My rebuild kit is on its way from jap4 and will be sending the cylinders away next week to be cleaned up.
Will let you all know how it goes.
Thu Sep 10, 2009 12:03 pm » Post: #15 » Download Post
Concerning statement #3; no holes necessary, they weren't forgotten.
Concerning statement #5; "Was being thrashed by an absolute dickhead" Is there another way to ride an NSR? Sounds like normal NSR protocol
