How difficult is it to change the spline shaft that shifts the transmission? I have done many rebuilds but have never been down to crank. I think my mech skills are pretty good but I'm no GP crew member.
I had a little problem going down to Laguna this past weekend. Was stuck in third gear from the time I got off the freeway. It was fun. Shaft is almost smooth now.
yeah its easy bro - clutch cover off and some minor dismantling will reveal the other end of the shaft which you can just pull through and then slide a fresh one in its place. I recommend a fresh oil seal too. Its about four years since i changed mine so i cant remember any finer details for you but i just remember it being much easier than i expected.
I got all the parts i needed off tyga and Matt wrote me a list of parts needed for a re-build and all the oil seals worth changing whilst i was at it;
Crankshaft x 1
Piston x 2
Piston Rings x 2
Piston Pin x 2
Piston Circlip x 4
Gasket, Cylinder x 2
Gasket, Head x 2
Gasket, Clutch Cover x 2
RC valve seal x 2
RC Valve Shaft E Clip x 2
Seal, Crank Left x 1
Seal, Crank Right x 1
Seal, Countershaft x 1
Seal, Gear Change Shaft x 1
Seal, clutch shaft actuator x 1
Seal, Kickstart x 1
The list maybe useful to you in future. _________________ After years of moaning about immigrants now i am one...
