I have been trying to find the part numbers for bits i need in the online manual but can see them. The illustrations say page XX so go there but can only se the part numbers for the tools to do the work.
Am i just blind?
Example pg 13-10 "Shock linkage needle bearing" says part number on pg 13-11 but i can find the part number for the bearing on the tools to remover the bearing. _________________ 94 mc28 SE
Have you tried to look for the part numbers on the online parts manual. I cant see any problem with the part numbers at the bottom of the page. _________________ If I have to take the carbs off once more...
The reference is to a page number (page 13-11), which is the page relating to removing/replacing the needle bearing. It's a reference to another page in the service manual, not for the part itself.
The only part #'s listed in the manual are service tools.
For part #'s you need to refer to the NSR Parts manual (double check all part #'s when ordering as accuracy in the parts manual is not a 100%. Parts have been superceded, or part's manual may be incorrect...).
