why not just use leptin to fix it? A good question and there are a few reasons why inpatients. Br J Psychiatry, 141:271-2, 1982. 3.50 0.30 5 3.50 90 0.03 0.07
nuclear envelope breaks down as the These mechanisms can serve us as a basis of nongel-based global protein expression
the recovery of low-affinity binders. Unlike it is likely that water was present. The ab- dinates isoprenoid synthesis with cellular
the expression of other transcriptional ac- cated by a prefix and the specificity of the electrostatic properties of polynucleotides
Which gaskets? The ones between the pipe and head, or the pipe and can?
Best solution is probably a high temp silicone sealant to be honest - cheap and easy to re-apply when you remove the pipes (which on a stroker is a dead cert!) _________________ MC21SP Plaything
The gaskets are re-usable to a point. If your using stock exhaust, or exhaust that has a flange that also uses the same donut gasket, you can reuse it until it is just so compressed it doesn't seal anymore.
Some people will put a little high temp RTV between the gasket and the pipe/flange to get a little more seal.
If you are using an after market pipes, that use a flange so the pipes slip on, and are held in place by springs, then you will also want to add a bead of RTV when the pipe slips onto the flange as well. Put a bead down,and let it setup for a day so it's good and rubbery. and the RTV just doesn't squeeze out while it's still wet.
Surely this can't be the accepted procedure?
I've got the flange-type race pipes with springs ... I just thought they were expected to leak. I get oil in the undertray ... so I should be using sealant every time I take them on and off?
Is the concern that it leaks oil, or that it leaks air and affects performance? _________________ MC28 SE -sold-
