I am in the process to rebuild the front forks of my MC28 SP... The bolts that hold all the internals (90116-383-721) (#22 in the parts manual) is ruined by the previously owner and I have to replace them... Can I use any bolt (stainless steel) from the local market here or I have to buy only the OEM...? And also does someone know the size of these bolts... As manual says it's a 8mm but what lenth...?
I might have some second hand ones kicking aroumd but I think it will be cheaper and faster if you order though Honda. _________________ If I have to take the carbs off once more...
