Is that true, are SE and SP cylinders distinguishable?
I've always been under the impression R's came with K marked up barrels and cylinders and SE/SP's came with L marked up ones. _________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
Does it have adjustable forks with anodised blue twiddly things?
Rear shock adjustable?
Dry clutch?
If yes to above then who cares what it is? It's got the bits you need. The Magtek wheels are an added bonus.
The SP forks (blue twiddly things) have a different design to the SE, where the rebound damping also controls the compression damping to a small amount.
This is definitely one area where all you MC28SP owners can say your bike (or at least bits of it) is better than the MC21
For all your info, the SE/SP have the same engine. The SE/SP cylinders are marked with an 'L', the R is marked with an 'H'.
