Well, you pretty much nailed it on the head... it's worth the motor, and that's about it!
Odds on are that the forks will be non-adjustable, there's not much point in having a second set of carbs really, and apart from the front wheel what else is of use?
If you can buy it cheaper than a spare motor and you really need a spare motor, then it's probably worth it. If you are buying it for the sake of spending money, then I would just buy the bits you need individually. You will only end up trying to find some way of disposing of the parts that are no good to you, or having them clutter up your garage/shed/kitchen/bedroom 'til the of time like the rest of us else. _________________ Andy.
