has anybody used the new flexi hose from samco,it looks like it will be the answer to my prayers.you can tie it in knots and it dosent crease,it will do nicely for the hoses i need for the rs rad if no one has used it then i will get some,when i get the sp back and be the guinea pig _________________ ive seen more tarts than mr kipling
Hi Si, are you talking about the stuff with a coiled metal wire throught it? If so its quite good as i have used some on my escort cab. It does the job but it does need quite a bit of space to bend in a right angle.
