hrc jet kit + piece repair
nsrdownunder
1993 Honda nsr 250 mc21 sp
Fri Oct 09, 2009 5:10 am » Post: #1 » Download Post
Hi guys i`m sorting out a jet kit for my mc21 i`ve got a + piece but it`s brocken . now looking at the hrc + piece and the original + piece the only difference seems to be the jet that`s open to air . So can i swap the jet over from the hrc one to the standard one . Does any one know if there are other differences.
Fri Oct 09, 2009 8:49 pm » Post: #2 » Download Post
Yes the X is the same its only the jet inside it that differs.
Fri Oct 09, 2009 9:49 pm » Post: #3 » Download Post
And it's red! Very Happy
nsrdownunder
Sat Oct 10, 2009 3:03 am » Post: #4 » Download Post
That`s great thanks for that guys that makes it much easier
coolhand91
    Send private message View user's profile Yahoo Messenger
Sat Oct 10, 2009 6:30 pm » Post: #5 » Download Post
Couldn't the plastic bits be fabricated at a plastics place if they had a original, or possibly an equivalent be found at a automotive/carb shop? The jets are common Keihin parts, so re-creating a full jet kit should be doable, correct?
nsrdownunder
Sun Oct 11, 2009 7:10 am » Post: #6 » Download Post
i though of that i was thinking of seing it i can get some jet kits made. Getting the the air jets right is the main thing . i don`t think it would be imposible but the cost of the first set would be the prob that`s if you got first set right . To be worth it you would have to sell a lot of kits . Maybe Matt at tyga has already looked into it or has though of it. lot cheaper do do that sort of stuff in tailand than hear in australia .Thats why we even import fruit , send our cows over sea`s and buy them back choped up . damn piss weak goverment.[/u]
Sun Oct 11, 2009 12:07 pm » Post: #7 » Download Post
It's also about the needles and the emulsion tubes... ask Fontyyy! Wink
Alternative jet kits certainly have been thought about before, trust me!
coolhand91
Tue Oct 13, 2009 4:09 pm » Post: #8 » Download Post
The emulsion tubes seem to be the holy grail part. I can't make heads or tails of the needle part numbers, or even figure out which type would be a direct replacement.
http://www.motorcyclecarbs.com/Keihin_Jet_Needle_Selection_Gu_W281C495.cfm
http://www.motorcyclecarbs.com/KEIHIN_N427-48_OEM_Jet_Needle__W252C1274.cfm.
Anyone with ideas on how to decipher this? I don't have any extra needles to check the numbers against.
nsrdownunder
Tue Oct 13, 2009 7:09 pm » Post: #9 » Download Post
here is a easy way http://page9.auctions.yahoo.co.jp/jp/auction/k116411426 Moriwaki-man can bid for you
Wed Oct 14, 2009 11:27 am » Post: #10 » Download Post
Making the plastic joints is easy......but costs a fortune if you want to go the plastic injection route.
Other thoughts would be casting PVC, alloy or brass parts. I've been machining some alloy molds recently for various carbon projects and I don't think it's too tricky to make a simple mold for these joints....Hmmmm.
Anyhow, I've just come up with a potentially cheaper solution, but I'll have to speak to my mate first.
Needles are a big problem. I had another mate carefully measure all the needles I have for various NSR's (stock and HRC) from the year dot, but trying to come up with a match is very difficult. At least I have the dimensions now and know somewhere that will make them, but not exactly cost effective for a small batch.
Other jets such as mains, pilots, pwrjets etc are easy to get.
nsrdownunder
Thu Oct 15, 2009 9:45 am » Post: #11 » Download Post
Hi matt
Instead of getting the X and Y pieces mate looking at stock and hrc ones the only difference seams to be the jets inside. So if you match the jets and just make replacement jets to put in stock X and Y pieces that should work it would be easy to test and get them to have correct air flow.
the emulsion tubes would be easy .That leaves the needles if can get the tappers of the hrc ones lenght. single,double or triple taper ?then it would be easy to get them made up.
I think most owners would like a kit, people are paying $300-600 for the hrc ones when avaliable .
Fri Oct 16, 2009 7:44 am » Post: #12 » Download Post
Concerning the X & Y pieces. Yes, it's simply a different jet size. But.....the majority of people (myself included) would rather just change the whole piece rather than mess around pulling old jets out and pressing new jets in, only to then break the piece and be worse off then when they started.
Jets would be removable so that people like Stephen can play with them.
Mold is designed, just gotta make it and cast the parts up.
mixalisen
Fri Oct 16, 2009 8:51 am » Post: #13 » Download Post
That would be perfect Matt... HRC kit is i think one of the most desireble modifications for the NSR... I think you will be able to sell a respectable amount of them...
Michael
Dexter
Fri Oct 16, 2009 9:12 am » Post: #14 » Download Post
Great news indeed. I ll be saving up Very Happy
