PGM Bits
2Smoke
1987 Honda NSR250 MC16
PGM Bits
Sat Oct 10, 2009 6:19 pm » Post: #1 » Download Post
Right.. I havent the faintest about the pgm setups for the nsr's, and my man on japan yahoo keeps sending me links to things that i dont know if they are worth having or not!
For instance, whats this?
Things like this worth bothering with?
Whats all this pgm stuff about anyway?
Paul
Sat Oct 10, 2009 6:25 pm » Post: #2 » Download Post
the top ones a hrc cdi box the same as i got with my hrc loom from tsr years ago,flywheels probably rs?,the silver box ive seen as f3 cdi's for mc18's.i may be wrong about the silver box,andy or stephen will put my right Very Happy
2Smoke
Tue Oct 13, 2009 8:49 pm » Post: #3 » Download Post
Cheers si, does anyone know the differences between the various PGM types then? Have done a bit of research but am still fairly unclear...
Wed Oct 14, 2009 7:31 am » Post: #4 » Download Post
Define "difference".
Early (87/88 ish) F3 electrics are called "pre-PGM" and are similar to early RS in that the CDI and RC valves control boxes are seperate. They cannot be plugged into a normal NSR setup unless you have the entire CDI/RC box/coils/adjustable stator (which requires the F3 cases and crank) etc.
Later F3 stuff was PGM-II and the PGM looks exactly the same as a mk-II mc18 or a 91/92 RS. It even plugs in and works on a normal mc18 mk-II loom (as does the RS PGM) but you need the engine work for it to make better (or even the same) power.
Wed Oct 14, 2009 11:39 am » Post: #5 » Download Post
To elaborate on what Fontyyy said. The PGM started in '87 on the MC18, but the F3 version used the CDI from the RS. '88 MC18 went onto the PGMII. We know the story after that.
As for differences, there are many. As in what they monitor and how they control the ignition timing and RC valve operation.
NF5 PGMII differs from the NH3 PGMII in timing and RC valve timing. There's also wire snips that can be done to alter the timing further. The NH3 PGMII offers one wire snip, the NF5 offers two snips.
I've done a fair bit of bench testing on the PGMIII and it monitors many things such as RPM, gear position, throttle posistion and throttle opening speed. The ignition timing, RC valve control and solenoid control are all controlled by these. Then you "wire splice" it and change it all completely!
For your info the stock PGMIII, spliced PGMIII and NH3 PGMII are very different in ignition timing.
2Smoke
Wed Oct 14, 2009 1:40 pm » Post: #6 » Download Post
Thanks Matt and Fonty. I was after the differences in what the various PGM's do (ie, I, II and III).
ta boyo's
Wed Oct 14, 2009 3:02 pm » Post: #7 » Download Post
PGM-CDI (commonly called PGM-I) is 1988 MC18R-J, PGM-II is 1989 MC18R-K, PGM-III is '90~'93 MC21, and PGM-IV is 1994~ MC28.
A complete PGM-I setup (including flywheel) will be the easiest to implement on an MC16, and optimised for the better porting, pipes, and carbs/air correction. The MC16 kit is designed to give 45~50hp, and that's about it. No matter what you do the MC16 electronics will always hold you back.
