Jack-up plates
Clarkie
Jack-up plates
Mon Oct 19, 2009 8:16 am » Post: #1 » Download Post
Anyone know a supplier for my 28?
Cheers.
Image Hosted by ImageShack.us
Mon Oct 19, 2009 2:19 pm » Post: #2 » Download Post
I imagine that would be a bit of a job on an MC28, as it uses a completely different setup to the other NSR's. I expect you will need to have a new "rocker" CNC'd up, but you will have to be very careful not to alter the geometry too much.
I'd try a PM to Matt@TYGA. He may be able to knock something up for you in SolidWorks and make it on his CNC machine, but don't expect it to be cheap! It will probably only be about 1/3 of the cost of a new shock with adjustable ride height though! Confused
Mon Oct 19, 2009 3:57 pm » Post: #3 » Download Post
He might mean footrests rather thank linkages Andy.
Mon Oct 19, 2009 4:11 pm » Post: #4 » Download Post
Never thought of that... never thought there was much wrong with the OEM position! OEM ride height on the other hand, can certainly be improved with a few mm extra.
Mon Oct 19, 2009 8:31 pm » Post: #5 » Download Post
Says the man with TYGA rear sets. Very Happy
Mon Oct 19, 2009 8:51 pm » Post: #6 » Download Post
Yeah, because I didn't want to put them on the Racer when it was becomming apparent that no-one else but us was putting anything into it... as it happened, the chassis disappeared along with my OEM rearsets which I would've liked back, but no chance of ever seeing them again I guess.
Mon Oct 19, 2009 9:02 pm » Post: #7 » Download Post
Well you could take them off and try riding without.
You might look a bit.....
Mon Oct 19, 2009 9:05 pm » Post: #8 » Download Post
I could never have that much style!
nsr.wayne
Mon Oct 19, 2009 9:16 pm » Post: #9 » Download Post
Andy wrote: the chassis disappeared along with my OEM rearsets which I would've liked back, but no chance of ever seeing them again I guess.
Tom had his chassis back along with all the other parts.
I sold my bodywork on and Tom had the forks off me
Clarkie
Tue Oct 20, 2009 6:32 pm » Post: #10 » Download Post
To be clear:
I have TSR rearsets, but I'd like some simple jack up plates to use the o.e footrests. I have to use plates to get around the JHA exhaust.
The JHA kit contains some spacers that perform the same function as a plate, but I'd prefer to have a plate, and get the footrest as low as possible around the exhaust. I guess a template and a chat with a metalworker is the best option.
Tue Oct 20, 2009 7:01 pm » Post: #11 » Download Post
I've got a pair. I'll see if I can arrange a pair to be made for you if you like.
Clarkie
Thu Oct 22, 2009 7:15 pm » Post: #12 » Download Post
That would be great - Cheers Very Happy
Just a blank plate, I can drill and tap the holes to suit.
Thanks again.
Thu Oct 22, 2009 8:03 pm » Post: #13 » Download Post
I'll dig them out and see if I can get them copied for you.
If I mark where the holes are in this set then you have something to guage from.
Clarkie
Sat Oct 24, 2009 12:01 pm » Post: #14 » Download Post
Marvellous. Very Happy
