I was installing the HRC Carb kit on my MC28 and I came up with something I didn't know what to do... Beneath of the stock needles there are one small washer... Do I have to put these washers again with the HRC needles or do I have to remove them...? Does anyone know what I have to do...? What do you do guys...?
If you mean the washers I think you mean, then if placed under the needle clip it will richen the mixture by half a position. They are good for fine tuning. When setting carbureation it is best to start rich (safe) and work backward. The washer under the needle is safer (richer) than no washer at all.
Yes I was talking about those washers... I thought the washers were there to protect either the needles or the slides from wear... Yes probably when putting the washers is like putting the clip one position up and the mixture is richer...
