my top piston has committed hari kari!!
lost compression on it , so looked up the port and the top front of the piston is missing above the rings.
it hasn't seized so i'm hoping cylinder damage is minimal!
got most of the bike apart tonight just gotta prize the cylinder off to have a proper look tomorrow!!
everyboby say a prayer for me !! lol
whats the likely cause? thought it might be blown head gasket damage??
it's standard well apart from the wire splice and a few holes in the air box.
think the fuel line became blocked with crap and caused it to run lean on the rear cyclinder, on the plus side the front cylinder which was forever running rich had a lovely brown plug in it!!! sods law!
anyone got an mc18 r5k cylinder and head they'd like to swop for cash??
thought i'd ask before i have to send the broken ones away to be repaired.
And could any one recomend somewhere to send the cylinder and head???
Be sure to get the new piston first and send it away with the barrel so they can plate the barrel to suit. _________________ MC21SP Plaything
that's weird as i was just looking at their web site.
do you know if they do heads as well dave as somethings been bouncing around in there making a right mess?
and do you have any idea how much they charge??
cheers.
Replate is about £100. Dunno about heads, not sure I'd trust a welded up one - can you get hold of a replacement one? _________________ MC21SP Plaything
Can you show us a photo of the damaged piston , then maybe we could help a bit more . I had a piston eaten away too , leaking head gasket . the head was warped and the top of the barrel !
couldn't see any cracks, i'll post some pics up tomorrow.
managed to get hold of a new head fom david silver and will get a top end re build kit from Gav. just gotta get the cylinder re plated then!
just what i need before xmas! it's cutting into my stella fund! lol!
Dave Ett wrote: Dunno about heads, not sure I'd trust a welded up one - can you get hold of a replacement one?
Yeah, but it's more fun cleaning it up and seeing if you can get away with running it _________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
I'd agree with you for a track bike Fontyyy, but for road use it's just a pain in the tits to have to pull it again. _________________ MC21SP Plaything
On my 1st pass top end rebuild, one on the barrels had a cracked exhaust bridge when it was examined by Aptec. I believe they use ultrasonics or something clever like that. It was welded and replated, but failed again within a few hundred miles. _________________ Why do things simply when you can complicate them
