If it's a fatt-ish black one, then it might just be the one behind the carbs. In front of the base and in between them. _________________ MC28 SE -sold-
Do you honestly think that pipe is in the same place as when it left the factory?
Mine all run to a catch tank - throwback to racing.
There's no long overflow for the carbs as I recall. Just breather pipes. The only overflow I can think of is for the coolant, which will run to the expansion tank under the seat.
What else has an overflow?
In fact, what else has a breather? _________________ MC21SP Plaything
its the only one to come out of the L/H/S near the peg, try and imagine this, it comes up in front of the shock and when it is about half way up the shock it turns right at the end towards the carbs...like a little cobra LOL _________________ MC21SP - Roth-tax
CBR400 - track
MC21R - sold
MC21SP - sold
Monkey,on mine(its stock)there are 5 pipes,2 thin ones go on the carb bowls,1 thin one is from the shock,1 fat one is from the rad bottle and the one you are on about is from a gearbox breather behind the top barrel(under the boost bottles).
It does sound like the gearbox breather. Quite large bore and black? All sort of tube like?
Gonna have to remove the tank, airbox, carbs, boost bottles and several knuckles. Then it'll fit on the vacant opening there!
Unless you can get your wee fingers in and feel under the gubbins. _________________ MC21SP Plaything
Yep, you're all right about the black one. I remember it's for the gearbox from a rebuild and it goes from in front of the carbs, underneath the middle of them both and follows the path you've mentioned... _________________ NSR300R - Why did i ever have a 250...
