ok, due to me buying waaaay to many NSR's and my garage being filled with bikes that dont even belong to me (thanks andy) Im in need of space.
I have a MC28 frame and log book for sale. The frame is on a "P" plate so around 1996-97 reg. The frame has a couple of flaws though. At some stage the bike must of been dropped, there is a small dent in the right hand frame rail where the bar end weight has caught it. On the same side the steering stop had been damaged. I had this welded and now both stops are fine again. Apart from this the frame is very clean.
The frame also comes with the engine rubber mounts and the steering lock unit, cable and lever that bolt into the head stock.
Im looking for around £100 plus some postage for the lot it if anyones interested. _________________ If I have to take the carbs off once more...
interested in the frame you have. does it have a title or MSO. maybe it's me but i don't believe the pm's are working either. please e-mail pics if possible nph3@netscape.com
thanks _________________ To much HP is barely adequate!
