Please help! primary and secondary gear alignment
SPENGILLY
Sun Feb 14, 2010 1:58 am » Post: #1 » Download Post
I'm trying to get my bike back together after replacing the shift shaft. I have a small problem.
When I removed the clutch basket, I did not check for the white mark on main drive gear. I didn't even think about it at the time. If I did check for the mark I would have noticed that there was no white mark to be found. Since I didn't check, I was unable to make my own mark. I do have a mark on the basket.
How can I make sure the two gears are in the right position?
MC21 - wet clutch
Thanks.
SPENGILLY
Sun Feb 14, 2010 2:28 am » Post: #2 » Download Post
Never mind. Embarassed After the fourth or fifth search I found the answer in an old post.
I will slap it together & not worry about the marks.
