Sprockets on a MC21 SE
Harold
Sun Feb 28, 2010 7:24 am » Post: #1 » Download Post
Hi
I have played around with sprockets on my bike for some time.
There is still one sprocket that I have not tested yet but I can't
seem to think that a 16T front sprocket would fit on the bike for there is not
much room for it unless you do some cutting work.
Would this sprocket fit without cutting anything?
Hermit
Sun Feb 28, 2010 9:10 am » Post: #2 » Download Post
i have a 16T front sprocket on my MC21 - it does indeed run tight clearances to the surrounding castings but it does fit straight on without the need for modification. I got mine from Jamie Wheeler through his NSR hompage.
Neal
Sun Feb 28, 2010 9:10 am » Post: #3 » Download Post
Howzit Harold ,
A 16 tooth can work , i have used one before . You need to modify a ns400 sprocket , i can take a photo later if you need .
ps : not sure if you got my message with details .
Neal
Harold
Re: Front sprocket
Sun Feb 28, 2010 9:50 am » Post: #4 » Download Post
Hi Neal. You are hard to find these days.
I have not received anything from you since that last time
I wanted Dr. Neels's number. You say I must try to get
a NS400 front sprocket? The reason I want to try this is
because I've got a 34T rear sprocket. This is strictly
for track use of-course. We must really try to get this email
thing working, it would be much easier for me.
Nice hearing from you again.
pbekkerh
Sun Feb 28, 2010 10:24 am » Post: #5 » Download Post
Hello, I have one new orig. Honda 23802-NH3-000, and two sligtly used (one Honda, one pattern) 16T sprockets for MC21
All for sale. See "Classified" section
Poul
MC21SE, KISS box
MC21SP, HRC box, racing loom
Harold
Sprockets for sale.
Sun Feb 28, 2010 1:22 pm » Post: #6 » Download Post
PM sent.
Thanx
pbekkerh
Sun Feb 28, 2010 3:01 pm » Post: #7 » Download Post
OK please use the thread in classified
Poul
MC21SE, KISS box
Neal
Sun Feb 28, 2010 5:47 pm » Post: #8 » Download Post
34 is low ! Were you able to pull that in top gear ?
I ran 16 38 at the east london gp circuit , it was a bit low on the exit of the corners but spot on for potters pass if you held it flat out .
Harold
16T front and 34T back
Sun Feb 28, 2010 6:05 pm » Post: #9 » Download Post
My friend who had a MC18 putting out 72Hp had that ratio on the local
killarney circuit. The bike ran 200psi compression on both barrels. That bike
did a 11second quarter mile obviously not with that sprocket ratio. He is helping me out on tuning but does not have a lot of time always.
