I haven't changed the transmission oil in my MC28 SP dry clutch in a long time, and I am about to change it. I was wondering where is the drain bolt, because I cannot see it under the engine. There are some golden bolts that don't look like drain bolts. In addition how much oil do I put in?
Just filled my SP gearbox with Castrol bike oil 10w/30 from Halfords.
Same colour as TTS so I liked it a lot. _________________ MC21SP Plaything
nsrmonkey wrote:judging by this I have just found in the workshop
"G.R.O. is an advanced synthetic formulation motor cycle gear-box oil covering the 10w/40 or 75w/90 viscosity range."
I should be getting 10/40
Just be careful quoting viscositys. 10w/40 is an engine oil, 75w/90 is a gear oil. They are measured on completly different scales.
A 10 weight gear oil is sh*t loads lighter than a 10 weight engine oil.
I know 99 percent of people are aware of this, but that leaves 1 percent that dont. _________________ Winning isn't everything, but loosing isn't anything
