TYGA Sprocket Holder Photo and question
geezagillard
Sat Mar 13, 2010 12:16 am » Post: #1 » Download Post
Was trying to fit the new lighter rear alloy sprocket holder that Tyga supply and had a question. As its not threaded like the standard steel Honda one, what are people using as a nut?
Normal nuts seem too deep for the length of the thread on hand (check pic) and I suspect shallow ones may lack the torque required?
Thanks
Neal
Sat Mar 13, 2010 5:58 am » Post: #2 » Download Post
Are those cap screws from the mc 18 ? On my 18 carrier they look the same as yours except that they screw into the carrier and on my 21 it is a bolt and nut system .
I can post a pic this afternoon
geezagillard
Sat Mar 13, 2010 7:26 am » Post: #3 » Download Post
That would be great Neal. I have an MC21 wheel here that shared the same setup to the MC18 so I had thought they were interchangeable
I have roughly measured the weight diiference on the kitchen scales....the original setup weighs approx 1.5kg and the lighter sprocket with the Tyga carrier weighs approx 750gms. This was a surprise as in hand the original feels a lot heavier. The lightweight alloy spacer kit I forgot to weigh before installing but perhaps another 200grams saved so approx a kilo all up.
geezagillard
Sun Mar 14, 2010 4:41 am » Post: #4 » Download Post
These are pics of the later MC21 arrangement.....are the threads able to be removed? Or are they a part of the sprocket? Seems limited for choice when racing? Maybe I wont be able to use my lightweight sprocket afterall.
Sun Mar 14, 2010 5:31 am » Post: #5 » Download Post
Just press the inserts out and back into the new sprocket.
geezagillard
Sun Mar 14, 2010 6:18 am » Post: #6 » Download Post
Thanks Andy appreciate the response....can you identify the threaded sprocket inserts in this parts list for me?
I'm assuming part number 2 is the rubber insert for the 5 sprocket bolts?
Sun Mar 14, 2010 8:16 am » Post: #7 » Download Post
The inserts come ready pressed in to the sprocket... that's why you press them out and fit them to the new one!
geezagillard
Sun Mar 14, 2010 9:17 am » Post: #8 » Download Post
Thanks
Neal
Sun Mar 14, 2010 5:38 pm » Post: #9 » Download Post
http://www.bikepics.com/pictures/1926511/http://www.bikepics.com/pictures/1926529/hi geeza ,you can see the difference between the two models , the 18 screws into the carrier and the 21 bolts onto it . The 21 sprockets need a bigger hole for the bolt to go through . You need to clean out those holes on your sprocket so the nuts don't get jammed .
Neal
Fri Mar 19, 2010 6:42 pm » Post: #10 » Download Post
OI Geeza , how did your sprocket issues work out ?
This is a light weight carrier http://www.bikepics.com/pictures/1930375/
The other sprockets i use when i ride to the shop for bread and milk !
geezagillard
Fri Mar 19, 2010 6:52 pm » Post: #11 » Download Post
Neal I have bought a secondhand MC21 sprocket as the nuts I need don't look to be an item you can buy separately. Where did you get your sprocket carrier looks very minimalist.
Neal
Fri Mar 19, 2010 7:29 pm » Post: #12 » Download Post
My friend made some for me , i have used it for a full season now and it looks perfect .
We will make some more at the end of April , They come in handy when i change sprockets at the track .
