could someone tell me if the steering damper is the same for all models of nsr
? would anyone have one for sale or know where i could get my hands on one
(i would only need the damper as i have the fitting kit)
thanks
I have a 'Sprint' damper that I would sell, it is like new and has everything to fit it, it was on my 28 but I have no idea what you want to put it on.
I know the mc-18 110-120 mm depending on the bracket used on the forks. mc-21 about 130mm again depends on the bracket used on the forks.
I have a daytona everyone says thay are crap which is probably true. It was cheap around $100 from a local shop ordered from Lockhart/ Phillips.
Steve
i would be puting it on an mc18 rk5
the fitting kit i have is the original part so i guess the damper would have to be the same size as the original one
LOBLOWE how much would you be looking if the damper will fit
