Never hurts to sling a new set of rings in! I usually go through 2 or 3 sets of rings to a set of pistons, to give you a rough idea. (Usually 2 sets.) _________________ Andy.
If you remove the exhausts and have a look up the port you might be able to see some blow by past the rings. If you do then the rings would be worthwhile changing. _________________ If I have to take the carbs off once more...
I'll be changing mine tomorrow. No they don't last long and mine ran almost all day so they will be well worn out. _________________ If I have to take the carbs off once more...
nsrjb wrote:i have compression readings of about 110 psi on both cylinders.
the bike drives fine but i dont think it has the same power it used to have.
do you think it is safe to keep riding with this amount of compression or should i get new piston rings???
I've just re-ringed my bike and measured 1000kPa (145psi) on each cylinder (at sea level). I think you should get a new set of rings. It will only make you smile
