MC21 footpeg bracket "guide" piece
Jim
Sun May 09, 2010 1:36 am » Post: #1 » Download Post
So I was removing the right side footpeg bracket on my MC21 when I heard something drop down into the bottom of the fairing. It turned out to be part 50610-KV3-680, part #5 on I14 of the parts manual. I didn't know this part existed so now my question is what is the proper placement of it so that it serves as a guide? If I knew how to post a pic I would but i don't (ah, figured it out, see pic below). I have it basically running parallel and just below the horizontal bracket. Would appreciate the help. Thanks.
-Jim
'93 MC21
nsrdownunder
1993 Honda nsr 250 mc21 sp
Sun May 09, 2010 3:41 am » Post: #2 » Download Post
That is the holder for overflow pipes . It goes on the bottom footpeg bolt between the pegs and the frame . Hope that helps your pic didn`t work.
The ring faces outwards
Jim
Sun May 09, 2010 3:58 am » Post: #3 » Download Post
From the picture it looks like there is supposed to be some sort of coiled piece hanging off the bottom, right? Mine doesn't have that (broken off I guess), and I have no overflow lines in the area. So can I just remove the guide piece or does it serve any other function, like affecting the angle or position of the lower footpeg bracket? Thanks a lot.
-Jim
'93 MC21
nsrdownunder
Sun May 09, 2010 9:09 am » Post: #4 » Download Post
Yes it should have a rod that goes into a loop your overflows from carbs , crankcase , rad overflow bottle go in it . It wont make a difference without it . Just watch where your overflows are . That there not infront of you swingarm where any overflow can go on tour rear tyre . Embarassed
Jim
Sun May 09, 2010 2:24 pm » Post: #5 » Download Post
Okay, cool, so I can save a gram or two of weight too. Very Happy Many thanks.
-Jim
'93 MC21
