Wheel bearing seals
cangus
Wheel bearing seals
Mon May 10, 2010 11:28 am » Post: #1 » Download Post
Just ordered wheel bearings from Tyga. But could not find wheel bearing seals on their site. Are these parts no longer available?
nxrsr20
Mon May 10, 2010 7:45 pm » Post: #2 » Download Post
You mean the dust seals? These are just a rubber boot, you can give the old ones a wipe and reuse them if there are no tears and in reasonable nick.
cangus
Mon May 10, 2010 7:54 pm » Post: #3 » Download Post
yes, dust seals. 19 year old rubber. I would like to replace them whilst in there. but i have looked and looked and can't find a supplier or a thread. is that what everyone does? reuss them?
Mon May 10, 2010 8:26 pm » Post: #4 » Download Post
You can use generic seals from any bearing supplier, but they are often deeper than the OEM Honda items. You should find it easy to find 10mm deep seals for example, which look a bit odd compared to the 8mm Honda ones if you look close enough, but no-one's ever noticed them on mine! Wink
Mon May 10, 2010 8:30 pm » Post: #5 » Download Post
Or get proper HRC wheels without seals Wink
cangus
Tue May 11, 2010 11:13 am » Post: #6 » Download Post
thanks. i'll see if i can source them from a local bearing supplier.
cangus
Tue May 11, 2010 4:46 pm » Post: #7 » Download Post
bearingdepot.com and metricoilseal.com can provide wheel bearing dust seals for MC21.
front wheel size is 28x42x8. They have 28x42x7.
rear wheel size is 30x44x5. They have this exact size.
They can be reached @ 732-563-2225 and are located in NJ, USA.
