Can anyone tell me the torque settings for the following.
swinging arm pivot nut and bolt
suspension linkage bolts.
engine mounting bolts.
cylinder head and cylinder nuts.
Thanks
Headman
If you look at the parts manual, the torque values for each part ( that needs torquing) should be in the associated notes. _________________ MC21SP Plaything
swinging arm pivot nut and bolt - mega tight
suspension linkage bolts - fairly tight
engine mounting bolts - tight
cylinder head and cylinder nuts - nipped up _________________ Please do not PM me technical questions, if you can't find it on the Forum start a thread
Swing arm pivot bolt: 9.5 kg-m
Suspension linkage bolts: 5.0 kg-m
engine mount bolts: 4.0 kg-m (does not include adjuster bolt/nut)
Cyliner head and cylinder nuts: 2.2 kg-m, 2.5 kg-m
This can all be found in the MC28 manual that is available in English, as well as many more interesting facts and detailed service procedures.
Check out the threads in the top of the discussion forums, or look in the NSR-WORLD.com marketplace (link on the left) for details...
