You would have to grind off the buttons, and replace them with the reusable type. I thing Brembo do them.
I have had good results by flatting back the carrier, masking the disc and half the button is easy. Put a little grease on the exposed button, paint, and when dry remove the grease and over spray with a little thinners.
I repainted my carriers a few years ago. I used a large drill bit to remove the outer part of the button If I remember right the button fell apart before I even got close to drilling into the disc or carrier.Then replaced them with some from Jamie's site. _________________
I taped up the disc and the rivets and painted the carriers.
I was really happy with the result. I gave the calipers and rotors about 5 coats each, 5min apart, using the hairdryer on them between coats, then baked them in the oven for about 30 min after. _________________ Winning isn't everything, but loosing isn't anything
