mc16 motor on mc21 elec
fstnsr
Tue Apr 19, 2005 5:39 am » Post: #1 » Download Post
hey does anyone know if i will be able to run a mc16 motor on mc21 elec. it is a pgm3. will run 21 carbs and maybe some race pipes. would it be best to run mc18 pgm2 electrics or even pgm1 elec.
the other option is put a big 4t into my 21 frame. any ideas?
thanks
jeff350lc
Tue Apr 19, 2005 8:37 am » Post: #2 » Download Post
not to sure on the PGM3. i do know that the MC16 motor has no speedo drive on the gear box output shaft. so you will have no speedo. i would think that if you can use all the electrics off the mc21, servo motor, coils, and the loom will connect to the charging system or swop from the 21 you should be ok
