cooling
dunkenb
1989 Honda NSR250 MC18
cooling
Sun Jun 20, 2010 9:12 pm » Post: #1 » Download Post
there seems tp be a few people reporting front cylinder fouling over the years and wondered if the way the cylinders are cooled could be a contributory factor ( the front cylinder recieves the cooled water from the rad first , where the rear cylinder gets coolant from the front cylinder)??
Sun Jun 20, 2010 10:07 pm » Post: #2 » Download Post
Have you done a temperature check to see how much difference there is between the two?
I suspect the water is moving quickly enough round the system for there not to be too great a change, though I would expect the front to run cooler simply because it is in the airflow, where the rear head hardly receives any.
dunkenb
Tue Jul 06, 2010 7:54 pm » Post: #3 » Download Post
Embarassed
Tue Jul 06, 2010 8:32 pm » Post: #4 » Download Post
I'm at a bit of a loss with this question... what do you think the (little plastic) splitter on top of the water pump outlet actually does?
dunkenb
Tue Jul 06, 2010 9:11 pm » Post: #5 » Download Post
ignore me i'm having a blonde moment!
Tue Jul 06, 2010 10:03 pm » Post: #6 » Download Post
I did wonder... I mean, questioning if something on an NSR could be improved to the level of an RGV?! ROTFLMAO
Wed Jul 07, 2010 6:31 pm » Post: #7 » Download Post
From my experience setting float heights, having good float valves & seats and especially a new fuel tap helped a lot with the front cylinder fouling up.
I reckon gravity is the biggest problem Very Happy
Wed Jul 07, 2010 6:34 pm » Post: #8 » Download Post
Hmm... I've found gravity my biggest problem on a number of occasions too! Confused
