Front Sprocket Float
Russ
Sat Jul 31, 2010 4:19 pm » Post: #1 » Download Post
Just checking the wear on the front sprocket and I noticed that there seems a lot of float of the sprocket on the drive shaft.
I am more used to sprockets having a nut to hold them solidly in place so this seems a bit different.
How much is normal
Russ
MC21SP
Sat Jul 31, 2010 7:42 pm » Post: #2 » Download Post
Yeah, there's some wiggle in it.
Sat Jul 31, 2010 9:36 pm » Post: #3 » Download Post
Depends what transmission you're using, eh Steve?! Wink
But yeah, on a stock NSR transmission, there's quite a lot of movement.
Sat Jul 31, 2010 9:56 pm » Post: #4 » Download Post
Yep, I spotted Dan's bolted on front sprocket at the last DP meet.........
Sat Jul 31, 2010 10:13 pm » Post: #5 » Download Post
The downside with those HRC transmissions is often the need to shim the rear sprocket carrier.
